1. JGRoc's Avatar
    Sorry, inadvertently posted this in the S7 forum. I have an Edge...
    Some background. Before the Nougat update I had added a 64G SD card to the S7 Edge. I followed the directions to force adopted storage. In my case, I allocated 75% to adopted, 25% to external.
    Worked great. The phone shows:
    Internal storage of XX used of 32GB
    SD card XX used of 47.31GB
    Portable Storage
    SD card xx used of 11.92GB
    So, there are 2 SD cards - one under phone storage and one under portable.
    Now running Nougat - it kept the adopted.
    But, when I plug into a Win 10 PC, and make sure File Transfer is the USB mode, it shows 2 drives under the Phone.
    Both are the same... Both say "Card" and both are the SD internal storage (47.3 GB)...
    As a side, I tried to backup the phone with Samsung Smart Switch (was going to do a factory reset) but it hangs at the transfer part (stays at 0% transferring Contacts).
    I suspect this USB issue is related.
    Thoughts?
    03-19-2017 06:13 AM
  1. Can't type Or text while connected to blue tooth in car?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-20-2017, 03:36 PM
  2. wifi won't turn on how to fix? Samsung Galaxy E7
    Last Post: 03-19-2017, 01:05 PM
  3. How do i attach a screenshot to ask a question?
    Last Post: 03-19-2017, 05:11 AM
  4. Can't type Or text while connected to blue tooth in car?
    Last Post: 03-19-2017, 04:14 AM
