I've had several generations of Galaxy phones so I know the usual tips. I have auto sync off, usually have location off, dont use crapps like Facebook, have disabled carrier and Samsung bloat, I have Material Dark theme with brightness usually at 30% or so...on and on. I just picked up an s7 edge (tmobile) about a week ago (updated to Nougat right away) and trying to maximize. Some observations and questions so far:
- Several nights I have gone to sleep letting video play and I can probably get 10+hrs SOT doing that. Why is it much less (more like 4 -5 hours)doing simple everyday stuff like texting, emails, some web browsing etc?
- Is the battery drain indicator in GSAM accurate? I have seen it running as low as -20 MaH and as high as -1000MaH but there doesn't seem to be much ryhme or reason to it. I can shut down everything and it still says it's draining at high number and other times it's very low.
- Does having Wifi on really drain battery that much? If I'm at home with good cell signal and unlimited data, am I better off turning wifi off?
- Does lowering screen res from WQHD (2560x1440) to FHD (1920x1080) really make much difference in terms of what your eye can see and\or battery life?
Thoughts\Comments? Thanks
