1. amyf27's Avatar
    Just started using a screen saver today, set it to display my photos. Does this typically pull more battery power than not using one?
    03-21-2017 01:01 PM
  2. pontiac005's Avatar
    Probably more than if the screen was off.
    03-23-2017 08:35 PM
  3. Daniel Barrett's Avatar
    I would assume so. The point of AOD is so you can see the time, calender, pictures, whatever you choose, but only the required pixels are lit. More pixels lit - more battery used.
    03-23-2017 08:40 PM
  4. LineKill's Avatar
    Yes, using a screensaver will use more battery than not using a screensaver.
    03-23-2017 10:28 PM
  5. Bosbouer's Avatar
    Yes it chews much more battery than the normal AOD option. Only practical I have for screensaver is in conjunction with my wireless charger where I use it as a bedside clock.
    03-23-2017 11:58 PM
  1. screensaver with photo"s on mxq box
    Last Post: 02-10-2017, 11:09 PM
  2. Live demo Screensaver Problem
    Last Post: 01-03-2017, 01:12 AM
  3. How do I disable a charging Screensaver?
    Last Post: 09-23-2016, 08:38 AM
  4. How do I disable a charging Screensaver?
    Last Post: 09-22-2016, 05:59 PM
  5. Replies: 1
    Last Post: 09-12-2016, 10:57 AM
