1. AC Question's Avatar
    I realised I had a software download earlier today so I did it. After finishing it I realised I had low battery so I let it completely finish and I put it on charge. I used the exact cable and plug I have used since day 1, the adaptive fast charging plug which came with the phone and cable. When I plugged in my phone it kept on disconnecting and connecting to the charger? I then got a separate plug and tried that and the charge fully worked? I'm not sure what's happened but it seems like my adaptive charger broke from the update. If anyone knows anything please help. Thanks you. Ps I recorded my screen for proof but I don't know how to add it.
    03-22-2017 04:15 PM
  1. HTC HD2 Review - A Blast from the Past.
    By Deke218 in forum General News & Discussion
    Last Post: 03-22-2017, 08:21 PM
  2. Replies: 1
    Last Post: 03-22-2017, 04:14 PM
  3. I also can't connect to Wifi since last update. WHY?
    Last Post: 03-22-2017, 04:09 PM
  4. How do I disable the new Search Bar in Nougat Email App
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-22-2017, 03:31 PM
  5. How do I disable the new Search Bar in Nougat Email App
