1. SereneJ's Avatar
    I had an OS update 3 days ago and now my weather widget is inoperable/missing from home screen. It's actually not even able to be removed to be re-added. Its still available in "widgets". I'm running Android 7 on an S7 EDGE.
    What I've done:
    Press and hold home screen to bring up widgets
    Select widget to add to home screen
    Get told its already there (its not)
    Repeat with other weather widget
    Get told there is already a weather widget so I can't add it until the other is removed.
    Ideally I'd use the one I had on my s5 but since I can't, the stock one was working fine but now not so much....
    03-23-2017 06:11 PM
  2. B. Diddy's Avatar
    Moved from the Nougat forum to the S7 edge forum, since this is likely to be a device-specific issue.
    Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-24999
    03-23-2017 08:30 PM
  1. How do I get a live weather wallpaper screen on my Samsung Galaxy 7 Edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-23-2017, 08:26 PM
  2. For anyone running stock
    By udnh in forum Google Nexus 6
    Last Post: 03-23-2017, 11:12 AM
  3. sir screen is a broken
    Last Post: 03-23-2017, 10:18 AM
  4. alarm widget dissapeared
    Last Post: 03-23-2017, 12:19 AM
  5. Replies: 0
    Last Post: 03-22-2017, 09:08 PM
