1. KBlack2595's Avatar
    ok so i have noticed with 7.0 the charging turns on and off alot when pluged in but it works fime when locked restarting dosent help and i dont think its the cable
    03-25-2017 03:46 AM
  2. mhinc's Avatar
    Similar thread, not the same but similar, try this
    http://forums.androidcentral.com/ask...ml#post5724869
    03-25-2017 04:35 AM
  3. KBlack2595's Avatar
    ok wiping the chace didn't help any thing eles I can do
    03-26-2017 02:02 AM
  4. mhinc's Avatar
    Sometimes there are issues after a new OS Update. And a Factory Reset is necessary. That would be my next suggestion
    03-26-2017 03:23 AM
  5. KBlack2595's Avatar
    ok im not doing a factory reset thats a pain and it seems to be ok after a bit or when phone is locked
    03-26-2017 03:29 AM
  6. mhinc's Avatar
    It may be a pain, but it's very common to have issues after an OS upgrade. And sometimes a factory reset is necessary to fix the issue, so it's your call. Unless it's a hardware issue, then a factory reset will be necessary to correct it. And since it started when you upgraded I would lean more towards it not being hardware
    03-26-2017 06:14 AM
  1. Two major problems after Nougat update
    By JF2014 in forum Samsung Galaxy S7 edge
    Last Post: 05-29-2017, 05:09 PM
  2. Battery life problem
    By alexmartins in forum Google Pixel & Pixel XL
    Last Post: 04-11-2017, 07:53 AM
  3. Booting problem
    Last Post: 03-24-2017, 04:43 PM
  4. clear cache on launcher3 does not fix problem? please help
    Last Post: 03-24-2017, 12:23 PM
  5. Replies: 1
    Last Post: 03-24-2017, 10:30 AM
