1. PsychDoc's Avatar
    Just got the OTA to nougat last night. All is well except my preferred browser is no longer doing text wrap. That's pretty much why I've used Dolphin for years. I have Jetpack downloaded but where it used to show up in the Dolphin settings (enable/do not enable) it is no longer there in Dolphin settings even though, as I already said, it's downloaded from the Play Store. It's like the Jetpack extension/add-on is not there even though I know it is. I've tried deleting and reinstalling both Dolphin and Dolphin Jetpack and the problem still persists.
    Does anyone know if this is a known nougat compatibility issue with Dolphin. Is there a fix for this?
    03-25-2017 05:32 AM
  2. amyf27's Avatar
    Does Dolphin have any updates pending? Maybe they're running behind on updating for Nougat compatibility. I don't use Dolphin but know some browsers have compatibility issues depending on what your doing or in this case what operating system version you're running
    03-25-2017 05:56 AM
  3. PsychDoc's Avatar
    I don't think a pending update is the issue here as I uninstalled and reinstalled Dolphin from the Play Store. I would assume that the version in the Play Store would, by definition, be their most current version with all updates current.
    03-25-2017 06:15 AM
  4. Tim1954's Avatar
    An unusual one here, perhaps a chat with the devs might help...
    03-25-2017 06:20 AM
  5. LineKill's Avatar
    The last update for Jetpack was March 29, 2016. More than likely this is the reason why it is not working with Nougat.
    younggreenanne likes this.
    03-25-2017 06:56 AM
  6. PsychDoc's Avatar
    Update: Here's what I heard from Dolphin.
    Bye, bye Dolphin...hello Opera!
    Joyce Zou*replied:
    Hi,*
    Thank you for your feedback and sorry for the inconvenience.
    Actually, we remove Jetpack on Android 7.0+ device.
    So Flash cannot be supported any more on android 7.0.
    Sorry again.
    Best,*
    Dolphin Support Team
    LineKill and younggreenanne like this.
    03-27-2017 04:24 AM
  7. LineKill's Avatar
    Thanks @PsychDoc for coming back and posting an update!
    03-27-2017 06:40 AM
  1. Get stuck with my vandroid E1C
    Last Post: 03-25-2017, 07:54 AM
  2. Skype not installing in Samsung J1
    Last Post: 03-25-2017, 06:49 AM
  3. Replies: 2
    Last Post: 03-25-2017, 06:16 AM
  4. Replies: 0
    Last Post: 03-25-2017, 04:54 AM
  5. ps2 emulator not working
    By AC Question in forum The Gamer's Lounge
    Last Post: 03-25-2017, 03:56 AM
