A
AC Question
This is the 2nd time in the last month i've accidentally turned "safe mode" on.
I have had the phone for 5+ years, & don't do this. (unfortunately, i don't recall, nor did i notate - the simple solution to this issue - when i found it via a "google/android search").
I don't want or need "safe mode" on - as it removes most of my downloaded apps.
The t-mobile websites, & a few others - only provide 1 solution, that would insult - even the least among us: "non-tech. People".
*(it is not just: "power off your phone", &/or, just: "re-start it").
Not the solution.
Thanks to all of you: Altruistic, selfless, & intelligent people - who help others out!
Peace
Not the solution.
Peace
