1. PsychDoc's Avatar
    It used to be a stand-alone app in the app drawer. One with an exclamation point IIRC. Now I have no idea where this is. I want to turn them off because they can be jarring and very embarrassing in a public place as they come through even if your phone is on mute or vibrate.
    Can someone with nougat walk me through how to do this?
    03-25-2017 11:40 AM
  2. LineKill's Avatar
    Go into settings and you will find it in connections > more > emergency alerts > settings.
    03-25-2017 11:53 AM
  3. SpookDroid's Avatar
    Not sure if it varies by carrier, but on T-Mobile it's not where the previous post states. It's on the Messages app, Settings, Emergency Alert Settings.
    03-25-2017 11:56 AM
  4. PsychDoc's Avatar
    Which Messages app? I tried both the Google and Samsung ones and I couldn't find it. I'm in Verizon. As you said, the first response didn't work either as I have no "connections" tab within settings. I have no idea what he is talking about.
    03-25-2017 12:04 PM
  5. LineKill's Avatar
    Apparently it varies by carrier☺
    03-25-2017 12:05 PM
  6. LineKill's Avatar
    Ok, I am on Verizon. There are two options for displaying the settings menu. When you are in settings click on the three dots and select view as simplified list and then follow where I previously noted.
    03-25-2017 12:17 PM
  7. PsychDoc's Avatar
    Ok, still not seeing it. Here's a screenshot of what I get when I click "simplified view." What am I missing?
    Edit: how do I post a screenshot?
    03-25-2017 12:22 PM
  8. LineKill's Avatar
    I don't see a screenshot, but in the other view in the settings menu it is in privacy and emergency > emergency alert > settings
    PsychDoc likes this.
    03-25-2017 12:26 PM
  9. LineKill's Avatar
    The more section should be all the way down at the bottom of the connections menu.
    03-25-2017 12:30 PM
  10. LineKill's Avatar
    If you would like help posting a screenshot tell me how you are viewing Android Central.
    03-25-2017 12:32 PM
  11. LineKill's Avatar
    Here is where it is in the simplified menu. If you would like I will post where it is in the standard menu.
    Where Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093244.jpgWhere Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093303.jpgWhere Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093318.jpgWhere Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093333.jpg
    03-25-2017 12:35 PM
  12. PsychDoc's Avatar
    Bingo! Thank you so much. That did it.
    03-25-2017 12:37 PM
  13. LineKill's Avatar
    Here is the standard menu.
    Where Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093615.jpgWhere Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093627.jpgWhere Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093641.jpgWhere Are "Emergency Alerts" Now That We're Updated To Nougat?-screenshot_20170325-093653.png
    For some reason this post had to get approval before it posted. It came after you had already found it. I guess I will just leave it here in case anyone else might find it useful.
    03-25-2017 12:37 PM
  14. LineKill's Avatar
    Your welcome. I am glad I could help☺
    03-25-2017 12:41 PM
  1. how to attach a file to a text message?
    Last Post: 03-25-2017, 05:55 PM
  2. Replies: 1
    Last Post: 03-25-2017, 05:49 PM
  3. On my 6P when I try to make a call my screen goes black.
    Last Post: 03-25-2017, 01:12 PM
  4. can we reverse the s7 software update
    Last Post: 03-25-2017, 11:29 AM
  5. How to get active app widget
    Last Post: 03-25-2017, 11:01 AM
