1. AC Question's Avatar
    Thank you for helping.
    My s7 edge said it needed to update 2 days ago and it was a big one. It changed the interface and menu and configurations. Now many of my daily apps don't work correctly and the battery life is much worse as is the internet speed.
    Also my samsung settings device management wants .10p to scan??? Wtf is that!?
    Is there any way to roll back or fix these issues?
    Android 7
    S7 galaxy edge
    Smg935f
    03-26-2017 06:38 AM
  2. jasonandrews25788's Avatar
    I only managed to fix these issues when I made a factory reset.
    03-26-2017 12:39 PM
  3. bandofbrothers2112's Avatar
    Sometimes the apps have to catch up / Update.
    Try clearing the system cache first before a Factory Reset.
    "Also my samsung settings device management wants .10p to scan???"
    I'm concerned your being asked to pay !
    Can you clarify how your navigating to this ?
    03-27-2017 01:11 AM
  4. Chris Topher5's Avatar
    How do I clear cache? I've run device managent.
    After you've run device management and system clean it says .10p to run virus checker.
    If that's the case in disgusted that Samsung are charging ...i can't even imagine how paying to use settings is ok.
    https://my.mixtape.moe/gfpfnu.png
    03-27-2017 01:11 PM
  5. Chris Topher5's Avatar
    So you reset but don't you have to update to use basic features?
    03-27-2017 01:12 PM
  6. Daniel Barrett's Avatar
    Lol "recommendations"
    Just don't click enable. It doesn't want anything to do it, you don't give your phone "10p" lol it's rating the device maintenance out of 100 and it's saying if you enable that option it bumps your rating up by 10.
    03-27-2017 02:11 PM
  7. bandofbrothers2112's Avatar
    I concur with @Daniel Barrett
    Personally I choose not to turn it on as imo it's a resources draw and not required.
    This is why I asked you to show us what you were seeing. A screenshot says it all.
    03-28-2017 12:43 AM
  8. crystinonfire's Avatar
    I had these issues when I updated to Nougat as well. Wiping the cache didn't fix the problem for me and I sadly had to do a factory reset. But now things are good, so it was worth it. ¯\_(ツ)_/¯
    03-28-2017 01:40 PM
  9. Chris Topher5's Avatar
    Thank you for the help. Haha 10p means 10 points lol that's messed up. I'd feel daft if it didn't clearly look like that.
    04-02-2017 06:11 PM
  1. Software update
    By Vatana123 in forum Honor 6X
    Last Post: 06-14-2017, 06:24 PM
  2. Replies: 1
    Last Post: 03-26-2017, 01:11 PM
  3. Need help on in locking my phone
    Last Post: 03-26-2017, 01:04 PM
  4. Blacklisyed samsung s7 edge
    Last Post: 03-26-2017, 07:25 AM
  5. Replies: 3
    Last Post: 03-26-2017, 05:08 AM
