1. tracypagedotnet's Avatar
    Is there a way to turn off themes or an easy way to create my own?
    The "problem" is that once a theme is set, I can't make significant changes to the homescreen because default apps like the phone and contact list no longer match.
    Any solution is acceptable since I'm really just trying to achieve a complete look when "skinning" my phone.
    03-26-2017 12:19 PM
  2. Abbers727's Avatar
    Now with Nougat after you apply your theme , you can also select the default icons (the way the default apps look )
    03-26-2017 11:29 PM
  3. tracypagedotnet's Avatar
    If I change the wallpaper on a theme, how do I change the background on the telephone keypad to match??
    03-27-2017 07:23 PM
  4. mysamsungs7e's Avatar
    How does that work?
    03-27-2017 08:32 PM
  5. bandofbrothers2112's Avatar
    When a person applies a Theme it typically comes with its own app icons.
    However a person can go back to the Stock ones.
    "At the top in the theme store there are 3 tabs. After you change your theme go into the icons tab and select default."
    03-28-2017 12:35 AM
  6. mysamsungs7e's Avatar
    Thanks. I figured that out lol.
    03-28-2017 01:05 AM
  1. Replies: 1
    Last Post: 03-27-2017, 06:24 PM
  2. can i add a custom recovery and a custom rom
    Last Post: 03-26-2017, 07:57 PM
  3. Can I share stuff between iPad without SIM and S6 over wifi
    By Julie Mcginty in forum General Help and How To
    Last Post: 03-26-2017, 01:52 PM
  4. Replies: 1
    Last Post: 03-26-2017, 11:46 AM
  5. S7 Edge panel disappears and not sure why?
    By Mark Zagotti in forum Samsung Galaxy S7 edge
    Last Post: 03-26-2017, 08:20 AM
