1. EMGSM's Avatar
    Anyone using secure folder on the S7/S7E? I like that Samsung added support for this after the update.
    03-26-2017 07:06 PM
  2. SpookDroid's Avatar
    Yup, I am for work e-mail. Works OK. Still don't know what the difference between this and My Knox (which was supported by the S7 Edge before My Folder) is... it feels and acts just the same.
    03-26-2017 07:51 PM
  3. bandofbrothers2112's Avatar
    Are you experiencing any extra battery usage from using the Secure Folder ?
    I ask as some have.
    03-27-2017 12:50 AM
  4. SpookDroid's Avatar
    Haven't really noticed any improvement, to be honest. Might be because I installed it when the Nougat update hit my phone and that did improve my battery...
    03-27-2017 02:07 AM
  5. EMGSM's Avatar
    I haven't noticed any issues on my end. I can still get over 4 hrs on screen time regularly.
    bandofbrothers2112 likes this.
    03-27-2017 11:49 PM
  6. jmagid51's Avatar
    I like it, it's working well for me. No real drain on the battery, that I can see. All of my financial are in it.
    03-28-2017 01:14 PM
  1. why no V20 security updates
    By huungryshark in forum LG V20
    Last Post: 03-28-2017, 03:40 PM
  2. TMo security patches?
    By Randy Ohio in forum LG V10
    Last Post: 03-27-2017, 10:15 PM
  3. Replies: 2
    Last Post: 03-26-2017, 03:05 PM
  4. Replies: 3
    Last Post: 03-26-2017, 05:08 AM
  5. Replies: 1
    Last Post: 03-25-2017, 06:36 PM
