Can I put a magnet on the back of my s7 edge battery case
  • Start date Start date
Are you sure you mean a magnet or just a piece of metal...... I have a slim metal piece on mine for my magnetic car mount and all is good.
It's this for something like the magnetic mount I keep seeing on Facebook ads? If so, the information says it's safe.
It does NOT affect wireless charging.mine still works. I have the scoche magic mount thing or whatever it's called.
I have one mounted right in the middle of the back of my case I use to mount on a magnetic mount. No problems.
I fancy one of these as well to mount my phone to a car mount.
Can anyone confirm if the NFC chip still works for android pay?
Does the magnet affect the battery, GPS, or wireless charging?
Thanks 👍
Not sure about nfc, never used it but I can confirm no battery issues, or wireless charging issues using magnetic mount
Gasho
