1. rub2008's Avatar
    I've tried looking for this post but can't seem to find one. I apologize if there is.
    Now that we've updated our s7 edge to nougat 7.0 is there a way to adapt the micro SD card? I know in marshmallow there was a manual way if doing it. Will that work for 7.0?
    Thanks to all!
    03-27-2017 04:48 PM
  2. smvim's Avatar
    Unfortunately Samsung hasn't been too keen on allowing adoptable storage in its products.
    XDA Developers has an article showing you how to manually enable it in your S7 Edge:
    https://www.xda-developers.com/enabl...7-and-s7-edge/
    03-27-2017 05:52 PM
  3. rub2008's Avatar
    Thank you! Has anyone tried this with Android 7.0 or higher? This might sound dumb but there's little to no risk with this correct?
    Might build up the courage to try this.
    03-27-2017 09:57 PM
  4. Bosbouer's Avatar
    Get a card from a reputable source and split the card to allocate part of capacity to internal memory. Keep in mind that you cannot control what part or which apps goes to the adaptable storage. In case of a card failure it can end up as a huge disaster.
    03-28-2017 12:53 AM
  5. rub2008's Avatar
    I will do just that. Since I pre-ordered the note 7 when it first came out I received the 256 SD card. I was planning on using that.
    03-28-2017 09:40 AM
  6. EMGSM's Avatar
    If you know anything about RAID configurations on a pc, it is similar to that and this is one reason why Samsung isn't too keen on the idea. As Bosbouer stated, it could be a disaster. Data could be mixed between internal and external sd so when the external is removed, half of the data could be on the internal storage. In addition the speed of the internal storage is much faster than any external sd card which could affect performance.
    Dngrsone likes this.
    03-28-2017 11:20 AM
  7. Bosbouer's Avatar
    I had a 64 Gb SanDisk extreme pro setup as adaptable storage. I noticed a marked reduction in overall performance with the setup. Once reversed speed was back to normal. I had to format the card in my pc and then again in edge to get it recognised.
    04-02-2017 07:57 AM
  8. Ipse_Tase's Avatar
    For me, the risk outweighs the benefits. You're probably better off doing some spring cleaning around those apps and keep the SD as storage.
    benjamminh likes this.
    04-02-2017 09:41 AM
  9. Btravelen's Avatar
    Good information here.. BTW, the term is Adoptable Storage Take Care
    04-02-2017 11:02 AM
  10. Dngrsone's Avatar
    I recommend only doing this with Samsung cards: other brands have a tendency to fail under the tender care of Galaxy devices, in my experience.
    04-02-2017 07:18 PM
  11. rub2008's Avatar
    Bad news. The adoption didn't work. I tried many ways. 100%, 50% but still noting. The commands work fine but the outcome doesnt show the SD card memory added to Internal.
    hero2qltevzw:/ $ sm list-disks
    disk:179,0
    hero2qltevzw:/ $ sm partition disk:179,0 private
    hero2qltevzw:/ $ reboot
    Nothing!
    Any ideas?
    04-02-2017 10:26 PM
  1. Can't copy all of my pictures and videos from SD card to computer!
    By jmv147 in forum Samsung Galaxy S7 edge
    Last Post: 03-28-2017, 11:58 AM
  2. Replies: 2
    Last Post: 03-27-2017, 04:04 PM
  3. Music to sd card
    Last Post: 03-27-2017, 03:46 AM
  4. Music to sd card
    Last Post: 03-27-2017, 03:25 AM
  5. How to encrypted sd with a broken screen
    By Bobbywood in forum Ask a Question
    Last Post: 03-27-2017, 01:43 AM
