1. AC Question's Avatar
    Speaker works fine. Whenever I use my headphones, I have to hold them in place. I don't hold it, headphones slip out.
    Frustrating.
    03-28-2017 12:49 PM
  2. NightOrchid's Avatar
    If its within warranty, Take to a SS store or post it back for repair
    Use some sticky tape to stick the phones into the socket while you use it..
    you can pick up a set of Bluetooth phones fairly cheap now
    Watch a Teardown video on YouTube, open your S7E up and replace the jack
    Morty2264 likes this.
    03-28-2017 04:37 PM
  3. Morty2264's Avatar
    The user above me has some very solid advice. I'd especially agree with taking the phone back to the store if it is under warranty, as the type of issue you're experiencing should not be happening.
    03-28-2017 04:38 PM
  1. Can't hard reset Samsung S5
    Last Post: 03-28-2017, 02:00 PM
  2. why did my fast charge not engage?
    Last Post: 03-28-2017, 01:48 PM
  3. Replies: 0
    Last Post: 03-28-2017, 12:37 PM
  4. What is com.ws.dm.?
    Last Post: 03-28-2017, 12:31 PM
  5. Replies: 1
    Last Post: 03-28-2017, 12:17 PM
