1. Becky021's Avatar
    My keyboard appears to be having a few issues. There is often a lag when pressing buttons - either it doesn't register ive pressed it for a good 10 seconds or ill be typing a word and it will freeze mid word. Leaving whatever button pressed larger on the screen. Going from letters to symbols is the same. 10+ second lag there. When i close a message or app with keyboard the app will close, keyboard remains in screen. Sometimes up to 30seconds. Also the back button - not in keyboard doesn't register its been pressed. Also taking up to 30 seconds to go back a page ect. This has been a issue since the last update. I have done a factory reset, issue still remains.
    03-28-2017 06:03 PM
  2. Tim1954's Avatar
    Open the keyboard app itself and wipe its cache and force stop it.. If that still doesn't work, dial *#0*# to get into the service menu and test the digitiser function there. If it fails the test, take it to a repair shop.
    03-29-2017 12:09 AM
  3. LineKill's Avatar
    It's kind of a bummer that Verizon has disabled the ability to enter codes:-(
    03-29-2017 12:41 AM
  4. jhousden9's Avatar
    Use SwiftKey and replace the stock keyboard.
    pontiac005 likes this.
    03-29-2017 01:28 AM
  1. Why my samsung galaxy tab pro s slow charging
    Last Post: 05-26-2019, 07:03 PM
  2. why did my galaxy s4 doesn't have software update??
    By Fagge Kano in forum Samsung Galaxy S4
    Last Post: 03-29-2017, 12:14 AM
  3. Settings menu for Music on my Galaxy Note
    Last Post: 03-28-2017, 05:21 PM
  4. Will the Galaxy S8 work in my Gear VR?
    Last Post: 03-28-2017, 02:17 PM
