I try to avoid doing reset\restore like the plague becasue it seems to take so much time and effort to get my phone back the way it was (i.e. apps reinstalled, home screens, folders etc) so I am looking for some tips to make this as painless as possible.
- does it matter if I do the reset through the phone's setting menu or via the recovery mode?
- for restore, ids there an order in which I should do things and what tools should I use?
I have a recent backup to my PC via Smart Switch. at one point in the restore process, if any, should I use Smart Switch?
Do the Google and Samsung Cloud backups restore the way smart switch would? At what point should I use these restore functions?
Thanks
Thanks
