1. hishaq96's Avatar
    Hi I factory reset my s7 edge today and since it has been sluggish not like it was before also the battery life still seems poor, what can i do?
    03-29-2017 06:12 PM
  2. hishaq96's Avatar
    Hi I factory reset my s7 edge today and since it has been sluggish not like it was before. Also the battery life still seems poor after the reset, what can i do?
    03-29-2017 06:16 PM
  3. tuscanybay's Avatar
    Set it up from scratch, rather than using a backup. Try to use it for a few days at close to factory condition, and see it is still sluggish.
    pontiac005 and LineKill like this.
    03-29-2017 07:32 PM
  4. hishaq96's Avatar
    I only did the reset due to battery life and phone was working perfectly fine it wasnt sluggish at all just after the reset this has started happening
    03-31-2017 06:11 PM
  5. 1812dave's Avatar
    I know it's just going to sound weird but trust me I had to do 3 factory reset over the course of a few days, months ago on my S7 because it refused to work properly with Bluetooth in my car despite having worked fine for many months after purchase. I almost returned the phone under warranty and got another one but I didn't want to get a refurb so that's why I did the third factory reset and thank God that fix the problem with Bluetooth
    You might get everything fixed up if you do one more factory reset and reinstall everything from scratch rather than from a backup as I've had problems doing resets and then backups from my computer
    03-31-2017 06:25 PM
  6. LineKill's Avatar
    It is always best to not do a restore after a factory reset. You just might be restoring what prompted you to do a factory reset in the first place☺
    pontiac005 and 1812dave like this.
    03-31-2017 08:12 PM
  7. pontiac005's Avatar
    Spot on!
    LineKill likes this.
    03-31-2017 08:13 PM
  8. pjwk81's Avatar
    Yep I'd echo what others said. I did a reset recently and I let my Google and Samsung accounts restore everything; phone was way worse than before with loads of bugs. Did a full reset since and started afresh. It took about 30 minutes longer but the phone is running brilliantly now.
    04-01-2017 02:44 PM
  9. hishaq96's Avatar
    What shouldn't I restore if I do factory reset again?
    04-01-2017 06:45 PM
  10. pjwk81's Avatar
    I had let Samsung back up my apps and then picked it to reinstall them after the reset. Had loads of small issues like Pocketcasts not showing up in Android Auto any more, Samsung Pass stalling on wepsite login, etc. After this reset I just took some screenshots of what was in my app drawer and started as a new device (ended up only reinstalling 75% of them anyway). All I restored from backup were my SMS and signing back into Google restored my contacts (only works if you use your gmail account for contacts). I even formatted my SD card before the reset this time round.
    04-03-2017 02:28 AM
  11. Stormyrose786's Avatar
    I am still having issues after f.r. & I haven't restored anything.
    02-26-2018 10:43 PM
  1. Replies: 1
    Last Post: 04-03-2017, 12:22 PM
  2. Can I recover my S6 when factory reset won't work?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-31-2017, 04:05 PM
  3. after latest VZW update no auto-brightness
    By mundo472 in forum Samsung Galaxy S7 edge
    Last Post: 03-30-2017, 11:06 AM
  4. Can I recover my S6 when factory reset won't work?
    Last Post: 03-29-2017, 05:53 PM
  5. How do i factory reset my extreme tablet generation 2
    Last Post: 03-29-2017, 05:23 PM
