1. Geoff Stuart's Avatar
    I have tried the right-to-left swipe and the hit-volume-up-and-power-switch options but I just can't get this phone to take a screen-shot. Is there a setting I need to change to allow this?
    03-30-2017 07:53 AM
  2. thunderbomb's Avatar
    It's left to right.
    03-30-2017 07:57 AM
  3. younggreenanne's Avatar
    Actually, try pushing the power button and the home button together. Does that work for you?
    03-30-2017 08:00 AM
  4. Tim1954's Avatar
    You need to enable that function in advanced features... The palm swipe one I mean
    03-30-2017 08:09 AM
  5. maddie1128's Avatar
    Once you enable it in settings the swipe works..either left to right or right to left. I use it all the time.
    thunderbomb likes this.
    03-30-2017 08:43 AM
  6. thunderbomb's Avatar
    I've always used left to right lol....
    03-30-2017 08:44 AM
  7. Daniel Barrett's Avatar
    Home button and power button
    03-30-2017 09:11 AM
  8. Geoff Stuart's Avatar
    Now on Nugget 7.0, can't find the permission in Settings for the swipe. Searched "Screen" and "Screen Shot" and came up empty. Where is it?
    03-30-2017 01:41 PM
  9. younggreenanne's Avatar
    It's an option under the Settings |Advanced Features screen,about halfway down the page. Samsung calls it Palm Swipe.
    (For me, anyway; your phone's setup may be different, depending upon your carrier, etc.)
    03-30-2017 01:45 PM
  10. LineKill's Avatar
    If you cannot find it in Advanced features, try searching in settings for "palm".S7 Edge cannot do a screen shot-screenshot_20170330-114848.jpg
    03-30-2017 01:50 PM
  11. Geoff Stuart's Avatar
    It was already turned on. Problem was your hand has to be TOUCHING the screen as you swipe. Now it works just fine. Thanks to all for the help.
    03-30-2017 02:00 PM
  12. JaneGI's Avatar
    Can I highjack this thread to ask .... how do you take a screenshot of the lock screen ??
    I know it's sounds stupid...who wants to take a screenshot o the lockscreen...but I do...
    I usually show my sister my wallpaper on my home screen with a screenshot, but I also want to send her a shot
    of my lock screen wallpaper..how do you do that ?
    Thanks
    03-31-2017 02:54 AM
  13. LineKill's Avatar
    Thanks
    While your on the lockscreen press the power and home button at the same time.
    BTW, not stupid at all;-)
    03-31-2017 02:57 AM
  1. Replies: 0
    Last Post: 03-30-2017, 07:46 AM
  2. Where do i find accsess my clip yray
    Last Post: 03-30-2017, 07:40 AM
  3. Replies: 1
    Last Post: 03-30-2017, 07:39 AM
  4. How do Unlock the privacy protection password
    By dummymail in forum Ask a Question
    Last Post: 03-30-2017, 07:16 AM
  5. Replies: 0
    Last Post: 03-30-2017, 07:08 AM
