1. Abby Normal's Avatar
    Well I just got my upgrade notice.....
    Reading about some of the issues some of you are having......
    Guess I will give it a try........ especially since I see that there is a way to revert back now....
    03-30-2017 08:04 AM
  2. Dngrsone's Avatar
    I have it downloaded, but am hesitant to pull the trigger: I like my phone the way it is right now.
    I have to find a way to un-download...
    03-30-2017 09:34 AM
  3. LineKill's Avatar
    If you find a way let me know so I can store it in my knowledge base (head)☺
    Dngrsone likes this.
    03-30-2017 10:17 AM
  4. comptechltd's Avatar
    You know I am one of the ones who came to the S7E from the Note 7 which in the short time I owned was my favorite phone. Nougat has made s7 as close as I can get to it. In my case Nougat has made this a better phone. Set it up, do a fdr or whatever you need to configure it and give it a couple of days to settle and you might just be happy.
    03-30-2017 10:20 AM
  5. Dngrsone's Avatar
    Hmm, well there are known issues that don't agree with me right now: S Health not working (I hear), the sheer amount of white (I'm dark-adapted, so white is no-so-good) and issues with tethering would really cramp my style. Especially that last as I have some travel ahead of me.
    03-30-2017 10:39 AM
  6. delco714's Avatar
    So far I'm enjoying it
    03-30-2017 11:02 AM
  7. LineKill's Avatar
    I really like Nougat. I like the UI. I have had no issues whatsoever. For me it was almost like buying a new updated phone.
    That being said, if you are perfectly happy with the way things currently are there really is no reason to update right now.
    I hope you find a way to keep the update from bothering you!
    Dngrsone and delco714 like this.
    03-30-2017 11:29 AM
  8. bandofbrothers2112's Avatar
    No issues on my s7 edge.
    Not needed to do a Factory Reset or System Cache wipe.
    If you do not like the white then use a Theme.
    I like the Grace Ui over Marshmallow as it's a more easier user experience.
    03-30-2017 12:51 PM
  9. pappcam's Avatar
    My S Health is working perfectly and there are 100s of dark themes available for Nougat.
    What issues with tethering?
    03-30-2017 01:14 PM
  10. Dngrsone's Avatar
    I hear that Fox Fi doesn't work anymore.
    I'm hoping that klink still does... I prefer a hard-wire to Wi-Fi anyway.
    03-30-2017 01:34 PM
  1. Samsung s7 Edge - Nougat - Email notifications Most Rececent
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-30-2017, 10:13 PM
  2. Samsung s7 Edge - Nougat - Email notifications Most Rececent
    Last Post: 03-30-2017, 02:02 AM
  3. Hotspot keeps turning off after Nougat update
    By AC Question in forum Android 7.0 Nougat
    Last Post: 03-30-2017, 01:10 AM
  4. Hotspot keeps turning off after Nougat update
  5. Replies: 0
    Last Post: 03-29-2017, 07:36 PM
