Samsung Galaxy S7 Edge "Failed to obtain IP address
Ms_Sarah
From my work Wifi, I was able to connect with no problems just a couple days ago. Then the phone updated and now it gives me the error "Failed to obtain IP address". I went online and found out about changing the static IP, I did this and it then says Connect, no Internet. Everyone else's phones are working and my boss has the same phone as me and his is working.
Steps I have done
***Forget Network
***Changed to Static IP, got "Connected, no internet" Switched back to DHCP (Without disconnecting from Static, goes back to Failed to Obtain IP address.
***Soft Reset Phone
***Setting reset
***Factory reset
***Forget the network then Cleared the Cache
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
Welcome to Android Central! Have you already asked your IT support at work about this? Can you ask them to try rebooting the work router?
Does the work wi-fi require a password? Or do you have to log in on a welcome screen the first time you connect?
BabyGurl-1
Steps I have done
***Forget Network
***Soft Reset Phone
***Setting reset
***Factory reset
kirk781
