How to delete my applied theme on my samsung 7 edge
OK so I download this theme and I thought I was just going to love it but I don't I have search I even got my parents to searching I tried and I just need help I have tried everything everything I don't see a delete button it just says applied and it taking to much data on mommy phone please help !!!! Asap
Re: How to delete my applied theme on my samsung 7 edge
To fix your problem, just go back to the theme store and apply the default theme. You will find it in "My themes"
How did you install the theme? If it is an app, you can go to Settings> Application manager, and then uninstall the app you installed.
Hi,
Settings > Wallpapers and Themes > Themes > Choose the Theme by tapping on it > Delete button at the bottom of the screen on Lh Side.
