1. Abbers727's Avatar
    I'm awful at applying screen protectors. I've tried Yootech one two times and It's failed. I'm trying for the third time with the YooTech screen protector.
    Does anyone know of any good screen protectors?
    04-02-2017 08:09 PM
  2. Dngrsone's Avatar
    Where's your problem? Getting it centered, bubbles, lint?
    04-02-2017 08:13 PM
  3. SpookDroid's Avatar
    I've had very good experiences with IQ shield ones (and they even replace it for you should you screw it up or if it gets damaged down the line). Only downside is that for the Edge you have to be careful which case you use as it can cause the edges to peel off.
    Dngrsone likes this.
    04-02-2017 08:13 PM
  4. Abbers727's Avatar
    I think mostly the bubbles. Sometimes, even when I clean it before applying the screen protector somehow lint or whatever gets under there between the screen and screen protector. I know Yootech does say wait 12 or 24 hours for the bubbles to go away on their own.
    04-02-2017 08:18 PM
  5. Abbers727's Avatar
    That's what I worry about. If I'll be able to take the case off or on with the screen protector.
    04-02-2017 08:19 PM
  6. SpookDroid's Avatar
    I'm afraid that with so little for the case to grab hold on the Edge phone this is going to be an issue with most cases/protectors. And things cannot be better with the upcoming S8 line.
    04-02-2017 08:21 PM
  7. Abbers727's Avatar
    @SpookDroid
    Yeah, that's what I'm afraid of.
    04-02-2017 08:28 PM
  8. dew066's Avatar
    Best one I have had so far for my Edge is the one done by Best Buy's Geek Squad. It is custom cut by them and comes with free lifetime replacements.
    I previously had the Zagg invisible shield HD and the glass one. The glass one was terrible and didn't respond uniformly. The plastic one lifted around the fingerprint reader.
    Abbers727 likes this.
    04-02-2017 08:29 PM
  9. Sandro Curia's Avatar
    Yes the best buy screen protector by far is the best for the s7 edge you can't go wrong 1 year warranty and installation put one on my wife's phone never had any issue
    04-02-2017 09:15 PM
  1. Replies: 2
    Last Post: 04-04-2017, 09:55 AM
  2. Screen turn on randomly while charging
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 04-03-2017, 10:50 PM
  3. Replies: 0
    Last Post: 04-02-2017, 06:37 PM
  4. Why can't i record my screen?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 04-02-2017, 05:15 PM
  5. Why can't i record my screen?
