1. noisemaker's Avatar
    Does anyone know how to make the notification shade more legible? I find the all-white with invisible delineation lines very difficult to read. Any suggestions? Thanks.
    04-03-2017 05:06 PM
  2. jhousden9's Avatar
    Would increasing the text size help? Settings > Display > Screen Zoom and Font.
    04-03-2017 05:15 PM
  3. Daniel Barrett's Avatar
    Don't think this will affect the notification shade. Didn't on mine
    04-03-2017 08:30 PM
  4. noisemaker's Avatar
    No change. Any other ideas?
    04-03-2017 10:25 PM
  5. ticketbabe2's Avatar
    Oooo, me too! I liked what it was before Nougat..much easier to read.
    04-04-2017 09:13 AM
  6. bandofbrothers2112's Avatar
    Do any themes change this ?
    04-05-2017 12:16 AM
  7. sweetypie31's Avatar
    No. Everthing changes except for the notification shade.
    04-05-2017 12:31 AM
  8. Macy72's Avatar
    I've downloaded a dark theme and it also changed the notification panel as well. Now I can see and read what's on it so much better
    04-07-2017 11:52 AM
  9. Miggy1218's Avatar
    What theme exactly? i would like a dark notification shade as well
    04-07-2017 12:04 PM
  10. Macy72's Avatar
    There were a few available but I am currently using one called 'sd black'
    Miggy1218 likes this.
    04-07-2017 12:06 PM
  11. sweetypie31's Avatar
    Is the op talking about the pull down menu with the toggles or the notification shade? The themes change the pull down menu, but not the notification shade.
    KPMcClave likes this.
    04-07-2017 12:33 PM
  12. Macy72's Avatar
    Is the op talking about the pull down menu with the toggles or the notification shade? The themes change the pull down menu, but not the notification shade. https://uploads.tapatalk-cdn.com/201...3227d21b5a.jpg
    https://uploads.tapatalk-cdn.com/201...288fc17157.jpg
    Actually you are correct. My apologies. The icons have a black background but the notifications still have a white one like your screenshots.
    sweetypie31 likes this.
    04-07-2017 01:44 PM
  13. keri2000's Avatar
    Same question. I hate the white. It's hard to differentiate between the different notifications and the font is smaller. Hoping this can be themed... Maybe people just need to build it into the themes now...? Hopefully.
    younggreenanne likes this.
    04-08-2017 12:43 AM
  14. Sam_Gs7's Avatar
    Another complainer here Not only with "Blurry Notifications" the whole
    phone GUI=General user interfaces is difficult to read even with my
    glasses on,.Grrr but at least we can change the rest of the
    Screen appearance with a -Dark theme- Let's hope
    Google fix this issue in its 1st update
    04-08-2017 01:06 AM
  15. KPMcClave's Avatar
    There aren't any themes that change the notifcation shade. So, I assume that there won't be any that will. It must be locked down to developers.
    On Marshmallow, you could install Good Lock from the Samsung app store and that would allow you to change the theming on the notifications shade, along with a few other UI tweaks not available otherwise.
    I've seen no indication at all that Good Lock is moving forward, though. Sort of a head scratcher.
    Sam_Gs7 and younggreenanne like this.
    04-08-2017 09:47 AM
  1. What happened to my Gmail notifications?
    By skynny70 in forum HTC 10
    Last Post: 04-07-2017, 08:16 AM
  2. What symbol is this on the notification bar of my xiaomi phone?
    By candelette in forum Xiaomi Android Phones
    Last Post: 04-04-2017, 06:04 PM
  3. Not getting Nougat update
    Last Post: 04-03-2017, 04:33 PM
