I can say that the system folder occupies a bit over 9GB of my 32GB S7 Edge with Nougat.
Yes, you can get by with 32GB, Of course, the S7 Edge has expandable storage with the SD slot, so I can't imagine that storage will ever be a problem.
I also use a 32GB Note 5, and I have not had an issue with storage space.
