1. venom0706's Avatar
    I want to set up a fingerprint scan on my S7E (for better security), however I have a few questions:
    1. How reliable is the fingerprint scanner? If the phone is stolen, will the person be able to unlock it somehow?
    2. After I do software updates, I always factory reset my phone. If I do a factory reset on the S7E, will the fingerprint scan get deleted and will I have to set it up again?
    Thank you and appreciated
    04-05-2017 05:25 AM
  2. aokusman's Avatar
    A stranger can't unlock your phone unless they have your finger. If you reset your phone you do have to enter your prints again.
    04-05-2017 06:42 AM
  3. justin1578's Avatar
    Your questions were answered above but I would like to add to it.
    Set up multiple fingerprints, minimum of 1 finger from each hand.
    Still set up a PIN that you wont forget. Please make sure you know your Google acct address and password in case you ever need to alternate reset the device. Without your Google info the phone is a brick then.
    04-05-2017 09:30 AM
  1. Question about buying from Best Buy
    By turb0wned in forum Samsung Galaxy S8 & S8+
    Last Post: 04-06-2017, 05:19 PM
  2. a question about tempered glass protectors
    By James Sumalinog in forum Ask a Question
    Last Post: 04-06-2017, 02:07 AM
  3. 2 questions about voice to text on GS 6
    By AC Question in forum Samsung Galaxy S6
    Last Post: 04-05-2017, 03:41 PM
  4. 2 questions about voice to text on GS 6
    Last Post: 04-04-2017, 02:42 PM
  5. 2 questions about voice to text on GS 6
    Last Post: 04-04-2017, 09:37 AM
