1. dk12345's Avatar
    I'm trying to block some numbers and spammers, usually I would just go to recent calls, select and click more and then add it to the block list. The only option I have now is to select delete.
    Any info appreciated, been getting bothered by a spammer I can't block.
    04-07-2017 01:14 PM
  2. bchain996's Avatar
    It's still there for me..
    dk12345 likes this.
    04-07-2017 01:17 PM
  3. dk12345's Avatar
    On the 1st screenshot you did there use to be an option from there. On the 2nd screenshot I get a random list of unsaved numbers, it seems..to me..i may be missing something, but that it can't be sorted by recent calls I tried putting in part of the end of the number and nothing came up..
    04-07-2017 01:30 PM
  4. dk12345's Avatar
    Okay, sorry...ive worked it out. I kept on going into call select option. I had the click to the side and get the below buttons that pop up, then select details and there's a block option in the top right corner.
    04-07-2017 01:35 PM
  5. LineKill's Avatar
    Also, after you press details you can long press on the phone number, below create contact, and select block number.
    dk12345 likes this.
    04-07-2017 02:09 PM
  1. I hate the look the latest update gave my S7 ...
    Last Post: 04-07-2017, 03:19 PM
  2. Replies: 0
    Last Post: 04-07-2017, 11:02 AM
  3. My weather widget on home screen is gone how i get it back?
    Last Post: 04-07-2017, 10:29 AM
  4. Phone not curernCannotCannot connect callsCannot make calls
    Last Post: 04-07-2017, 08:08 AM
  5. My Samsung s7 phone is locked
    Last Post: 04-07-2017, 04:32 AM
