1. AngieL65's Avatar
    For some reason OK Google doesn't work with AOD on. It will work with the lock screen on but only when the screen is showing not when it is off and not when the AOD is on.
    bigmo555 likes this.
    04-07-2017 04:21 PM
  2. Darius DuPree's Avatar
    Yeah it's very annoying, but I haven't found any workarounds other than disabling the AOD
    04-07-2017 05:53 PM
  3. LineKill's Avatar
    Currently it will only work, with the screen off, if it is charging.
    04-08-2017 01:10 AM
  4. Sam_Gs7's Avatar
    Weird oK Google Assistant behaviour isn't it 'cause it works on
    my SGs7 with the AoD=AlwaysOndisplay enabled and No
    need to keep it charging..When I ask it oK Google
    open "Android central" it does Let's hope
    a user comes up with a solution
    04-08-2017 01:23 AM
  5. AngieL65's Avatar
    I switched over to S Voice it seems to be working correctly.
    04-08-2017 05:46 AM
  6. Btravelen's Avatar
    So, with your SGs7 sitting idle with AOD on and NOT on charge, it will wake when 'Ok Google' is used?
    The only way it 'sort of' works on my SGs7 Edge is using s-voice, but s-voice sucks...
    04-10-2017 08:16 AM
  7. Btravelen's Avatar
    That is my experience... My original Droid Turbo was typically flawless using this feature from sleep and I really miss it..
    04-10-2017 08:18 AM
  8. LineKill's Avatar
    Yeah, some of the LG phones will also wake with the screen off. There are a few others also, but not my S7 edge. I am not exactly sure why, but it sure would be nice if it did.
    There was a thread where one person said theirs worked, they were in the Google Services Beta. The thread died and there was never really any proof that it worked, this was a few weeks ago.
    I don't know if it is a Samsung thing or a Google thing. It is not consistent with different devices and not even consistent with different devices made by the same manufacturer.
    04-10-2017 08:29 AM
  9. Btravelen's Avatar
    It appears to me to be a Samsung issue.. S-Voice awakens the phone from sleep by voice, but it works so poorly that it's useless to me.. Assistant will work if it's on charge, or if I press the home button first.. Curious
    04-11-2017 07:43 AM
  1. Google Now Cards displays Team News cards, cannot remove
    By Rick Jacobs in forum Samsung Galaxy S7
    Last Post: 05-08-2017, 04:44 PM
  2. Possible long term issues with the S8?
    By flyingkytez in forum Samsung Galaxy S8 & S8+
    Last Post: 04-16-2017, 11:25 AM
  3. Cannot communicate with Google servers
    Last Post: 04-12-2017, 04:50 AM
  4. help me get Google out of my life!
    By Nate Hogue in forum Ubuntu for Android
    Last Post: 04-08-2017, 04:28 AM
  5. Replies: 1
    Last Post: 04-07-2017, 01:50 PM
