1. mnc76's Avatar
    I have an S7 edge with the Nougat update, and I've been using the Samsung Messages app for text messages since it's the fastest text app I've used.
    However, when I send a group text, the replies are not going back to the group, but are going back to each person's individual thread.
    When I switch to Google Messages, however, everything works perfectly. Replies to my group messages go back to the group as expected.
    The problem is, Google Messages is extremely laggy and I'm not impressed with the UI, so I'd prefer to use the Samsung app (which looks really good after the Nougat update).
    Is there any way to fix this issue that anyone has found?
    04-07-2017 10:33 PM
  2. tennislvr8's Avatar
    Go to settings in the app, click more settings them multimedia messages and make sure group messaging is turned on. If it is I don't know what the problem is.
    04-08-2017 09:02 AM
  3. mnc76's Avatar
    Thanks for trying to help!
    Unfortunately, there is no Group Messaging settings option in the Samsung Messages app (the Nougat version).
    On the 'Multimedia Messages' settings screen, the options are :
    • Delivery reports
    • Read reports
    • Auto retrieve
    • Roaming auto retrieve
    • Set restrictions
    But there is no 'Group Messages' toggle.
    I went 'Settings > More Settings > Multimedia messages' to get to that screen.
    Group text replies not going to group thread-screenshot_20170408-143256-002-.jpg
    04-08-2017 02:26 PM
  4. tennislvr8's Avatar
    I have nougat too and here is what I see, I am on Verizon.
    04-08-2017 03:56 PM
  5. mnc76's Avatar
    WTF... That is so weird! Thanks for the screenshot!
    Can I ask what version of the app you have?
    I went to Settings > Apps > Messages
    in the phone Settings.
    It says I have version 4.0.75.
    04-08-2017 10:50 PM
  6. LineKill's Avatar
    It varies by carrier, not by app version.
    BTW, Verizon is on 4.0.65.
    04-09-2017 12:54 AM
  1. White text on white bg with latest software update
    Last Post: 08-02-2017, 04:04 AM
  2. Replies: 0
    Last Post: 04-07-2017, 10:13 PM
  3. Cannot text inflight
    Last Post: 04-07-2017, 10:12 PM
  4. Replies: 1
    Last Post: 04-07-2017, 09:28 PM
  5. my contacts don't upload to my ford territory via bluetooth
    Last Post: 04-07-2017, 09:15 PM
