1. abdullahq7's Avatar
    I have a few hairline scratches on my s7 edge camera lens and one scratch. Will these scratches affect the pictures I take?
    JustPassin likes this.
    04-10-2017 09:57 PM
  2. JustPassin's Avatar
    04-10-2017 10:00 PM
  3. smvim's Avatar
    I'd imagine there will be some affect, hopefully very minor so it's only evident because you know exactly what you're looking for. But the best way to determine if it's noticeably bad or just completely insignificant is to take a few test photos, some indoors with the flash enabled and disabled, and some outdoors.
    04-10-2017 10:08 PM
  4. SpookDroid's Avatar
    Like others have said, it greatly depends on how deep, location, thickness, etc. of the scratches. There WILL be an effect, but whether or not this is noticeable depends on the factors combined. A deeper scratch will be noticeable, but several small ones might cause the auto-focus to struggle, while a thick faint one across the middle of the lens might show up as a smudge on all your pictures. Think of a small, thin thread. If you focus on it while it's close to your eyes, you'll see it. But if you don't move the thread and focus on something far away, chances are you won't see the thread anymore. Now add a bunch of threads and no matter what you do, you'll see them.
    Also, unless the glass is somehow broken or a more serious issue is happening, the scratches should be on the protective glass for the camera, not the lens itself.
    04-10-2017 10:15 PM
  5. Ca_lvn's Avatar
    YES
    04-10-2017 10:26 PM
  6. 1812dave's Avatar
    Post some pictures and then we will decide. Lol
    justin1578 likes this.
    04-11-2017 12:25 AM
  7. abdullahq7's Avatar
    Can't attach pictures because they are too large. Any other way to attach pictures?
    04-11-2017 04:59 PM
  8. abdullahq7's Avatar
    Ok here are the pictures
    Attached Thumbnails Do scratches on Camera Lens Affect photos?-20170411_165846.jpg   Do scratches on Camera Lens Affect photos?-20170411_165926.jpg   Do scratches on Camera Lens Affect photos?-20170411_165931.jpg   Do scratches on Camera Lens Affect photos?-20170411_170349.jpg   Do scratches on Camera Lens Affect photos?-20170411_170402.jpg
    04-11-2017 05:16 PM
  9. 1812dave's Avatar
    They have nice contrast so I would say you're okay
    04-11-2017 07:31 PM
  1. v20 video upside down on tv
    By recDNA in forum LG V20
    Last Post: 04-14-2017, 10:52 AM
  2. Replies: 2
    Last Post: 04-11-2017, 06:03 PM
  3. Screen shot sharing on whastapp
    Last Post: 04-10-2017, 10:45 PM
  4. I cannot install any mobile antivirus programs on my LG phone
    Last Post: 04-10-2017, 08:40 PM
  5. Why do I not have a saved email folder
    Last Post: 04-10-2017, 07:57 PM
