1. AC Question's Avatar
    What I want to know is will this still work when i go on holiday to the USA with my UK sim in it. Im on 3 advanced plan with feel at home, so I can use my allowances whilst in the USA.
    04-12-2017 12:52 PM
  2. Rukbat's Avatar
    1. Try https://swappa.com/search?q=g930f&re...cUvbUpU5756118 There aren't usually many of them, but there are some.
    2. It won't work with a 3 SIM, but the plan you're on may give you free roaming here. Or you can go month to month (US$45) with Straight Talk (AT&T usually has the best GSM coverage, so specify an AT&T SIM if you go that way).
    04-12-2017 03:01 PM
  3. Bosbouer's Avatar
    1. Try https://swappa.com/search?q=g930f&re...cUvbUpU5758357 There aren't usually many of them, but there are some.
    The international model of the s7 edge is the G935f.
    04-13-2017 11:05 PM
  1. Home screen icons locked and cant unlock
    Last Post: 09-07-2018, 08:59 AM
  2. Replies: 79
    Last Post: 04-18-2017, 09:59 AM
  3. Replies: 1
    Last Post: 04-12-2017, 05:07 PM
  4. Replies: 1
    Last Post: 04-12-2017, 02:34 PM
  5. Replies: 1
    Last Post: 04-12-2017, 12:33 PM
