1. GonFreecs's Avatar
    I got a notification for an update on my s7 edge that seems dodgy due to the version number, Is it legit?
    Attached Thumbnails Is this legit please help thanks-screenshot_20170414-055917.jpg
    04-14-2017 01:02 AM
  2. SpookDroid's Avatar
    Some people have been reporting getting the newest security patch in the past few days, so maybe this is that? I haven't seen any new updates on mine (T-Mobile version) BUT I'm currently out of the country so that might be crippling OTAs.
    04-14-2017 01:12 AM
  3. Tim1954's Avatar
    I got a smaller update recently, bug fix type stuff on my S7 Nougat.. Best way is to ignore Popups and go to the device settings, about device... Software updates...
    04-14-2017 01:17 AM
  4. bandofbrothers2112's Avatar
    I had an update a few days ago too.
    It didn't bring with it an update to my current February security patch.
    I agree with the advice to manually search in your phones settings for updates , unless you've set your phone up to search at set intervals.
    LineKill likes this.
    04-14-2017 02:07 AM
  5. LineKill's Avatar
    I agree with all of the above. Great advice given.
    04-14-2017 02:37 AM
  6. GonFreecs's Avatar
    Thanks it shows up when I go to settings and update but the only thing that's weird to me is the number
    04-14-2017 01:00 PM
  7. bandofbrothers2112's Avatar
    You should be good to go then if it's showing up there.
    04-14-2017 01:24 PM
  1. please help me
    By Abdull Muizz in forum HTC Desire 626
    Last Post: 04-15-2017, 12:00 AM
  2. Why is my rca tablet pressing buttons i dont even press?!
    Last Post: 04-14-2017, 07:24 AM
  3. Replies: 1
    Last Post: 04-14-2017, 02:12 AM
  4. Replies: 1
    Last Post: 04-14-2017, 01:35 AM
  5. i cant connect to wifi, can you help me?
    Last Post: 04-14-2017, 01:28 AM
