1. AC Question's Avatar
    While trying to upgrade my Claro galaxy s7 edge from android 6.0 to 7.0 using Smart Switch my phone crashed and the software got corrupted. (couldn't do it through manual/automatic update).
    Now i'm stuck on the Window : "An error has occurred while updating the device software. Use the emergency recovery function in the Smart Switch PC software". I tried both the emergency Software Recovery and Device Initialization but both failed with error "failed to run firmware upgrade unknown error occurred". Tried it in different computer, restarting both the devices, reinstalling device driver. Nth worked.
    Finally i searched forums and tried to flash custom rom using ODIN. Thing is while downloading the ROM my phone went to Download mode when i pressed "Volume up" + Power + Home button but now the combination just does nothing and i'm stuck on the "An error has occured window". I tried 300k tool and also Both volume + power + slide in usb cable combo but nth happened.
    Pressing Volume down Power and home (recovery mode) brings me to this same window again and again. Just waiting for the battery to die and start anew.
    Just 4 days with my phone. Any help to solve these problem are appreciated.
    04-16-2017 02:08 PM
  2. tuscanybay's Avatar
    Send it back to Samsung
    04-17-2017 07:04 AM
  1. Is there a nougat update on j5 prime?
    By James Sumalinog in forum Samsung Galaxy J Series
    Last Post: 06-29-2017, 06:37 PM
  2. Will Galaxy Grand Duos ROMs work on Galaxy Grand Neo Plus?
    Last Post: 04-16-2017, 03:42 PM
  3. why did keyboard won't show on samsung galaxy luna
    Last Post: 04-16-2017, 03:30 PM
  4. why my mobile getting hang ?
    Last Post: 04-16-2017, 01:17 PM
  5. Is there a nougat update on j5 prime?
    By James Sumalinog in forum Ask a Question
    Last Post: 04-16-2017, 12:38 PM
