1. AC Question's Avatar
    This is very annoying. I remember that since the latest Android update on my S7 Edge, the opened programs the are always limited to the latest 5 apps used. I always use approximately 10 apps and they always kept showing under the Recent opened tabs before the update.
    Did they change this or can I set the maximum tabs now with the latest update or something ? Although I didn't manage to find such an option (yet). Please help me. I want all opened programs to be still there under the " Recent " key, because now if I want to use Adobe Acrobat to read something, and if this was a program I used much earlier before the latest opened 5 programs, it will not be under the Recent tabs list anymore. Therefore have to go to Programs again and open the program there. And when I do it's still in the phones memory somehow, because then it does open at the exact point I was reading last time.
    Anyone know how I can fix this Recents key malfunction ? Or is this normal since the latest update and/or can I change the settings for the Recent key ?
    Thanks.
    04-18-2017 03:37 AM
  1. How to unlock an at&t galaxy s7
    Last Post: 05-03-2017, 07:26 PM
  2. Replies: 45
    Last Post: 04-19-2017, 10:14 AM
  3. Good morning Trying to connect my LGg4 to my pc
    By AC Question in forum LG G4
    Last Post: 04-19-2017, 12:26 AM
  4. Why my play store irror
    Last Post: 04-18-2017, 05:23 AM
  5. Why memory card is not functioning in my gpad-706 ?
    Last Post: 04-18-2017, 05:14 AM
