1. Josh Sadorra's Avatar
    So my S7e won't connect to any mobile network, so I am getting a replacement from AT&T. How good is the stock phone transfer app? I'm just worried about the different games and apps that might be stored locally or something and will be lost when I transfer if it relies on my Google account. is there a way to check which of my apps will be backed up through my Google account ? This is the one area I'm really not sure how to deal with, I always feel like I'm leaving something behind on the old phone.
    04-18-2017 01:07 PM
  2. LineKill's Avatar
    Open Google Drive and tap on the 3 lines in the upper left. Then go to Backups and tap on your backup to see what has been backed up.
    Unless your game saves have been backed up in the cloud, you will most likely loose them.
    There is an app called Helium in the Play Store that will backup some of your data, but I am not too familiar with it myself.
    04-18-2017 01:38 PM
  3. LineKill's Avatar
    Oh, Samsung Smart Switch works really well for your backups.
    04-18-2017 01:42 PM
  1. phone still bricked after flash
    Last Post: 04-21-2017, 09:43 AM
  2. Replies: 1
    Last Post: 04-18-2017, 03:04 PM
  3. Why is my phone (S7) constantly at 30 C when wireless charging?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-18-2017, 12:54 PM
  4. Why won't my phone download android system update ?
    Last Post: 04-18-2017, 12:21 PM
  5. can anyone remember what O2 used to be called before they changed??
    By northolts last whitey in forum Ask a Question
    Last Post: 04-18-2017, 12:19 PM
