1. ImpossibleGirl624's Avatar
    So my Verizon Samsung GS7 Edge finally updated to Nougat a few weeks ago and I'm having issues with certain apps going to sleep when my phone isn't charging. If I forget to plug my phone in before bed my alarm clock app goes to sleep and doesn't go off in the morning, which is a huge problem. I also have a radio station app that goes to sleep every 5 minutes, which is less critical than the alarm clock but still annoying. I've added both apps to the "Unmonitored" list in the battery settings but that hasn't helped. Am I missing another setting somewhere?
    04-19-2017 12:43 AM
  2. YouBlue_dev's Avatar
    Wow, the alarm app shouldn't be going to sleep. Are you using the stock alarm app, or a 3rd party?
    You can try in the Battery settings, tap the menu icon in the top right and click "Advanced settings." From there, turn off "App power monitor" completely. If that doesn't solve the problem, then it's not a power issue.
    04-19-2017 11:21 AM
  1. Replies: 2
    Last Post: 04-19-2017, 10:28 PM
  2. Replies: 13
    Last Post: 04-19-2017, 01:48 PM
  3. If the iphone 8 look like the S8, can Samsung sue?
    By goodintentions in forum Samsung Galaxy S8 & S8+
    Last Post: 04-19-2017, 09:35 AM
  4. How can I reflash my samsung s5?
    By fincx in forum Ask a Question
    Last Post: 04-19-2017, 01:09 AM
  5. How can I print my Samsung health each week
    By curlytop143 in forum Samsung Galaxy S5 Active
    Last Post: 04-19-2017, 12:38 AM
