Yes, it's removable. It's a blue GPS raindrop/teardrop trying to locate your current location for an app (lication).
Do the following:
1. Go to home screen and TAP bottom right (APPS), and proceed to SETTINGS.
2. TAP SETTINGS.
3. OPEN CONNECTIONS and TAP BLUETOOTH [2nd option] OFF (Just momentarily)
4. TAP LOCATION [9th option] OFF (Just momentarily) while still in Connections via SETTINGS.
5. In Settings go into NOTIFICATIONS to TURN OFF ALL APPS Getting Notifications (Just temporarily)
6. Last go into Settings, DEVICE MANAGEMENT and FIX ALL that is needed or where you see a number. Once your device is at 90% or higher, BEST @ 100%, THE GPS RAINDROP/TEARDROP IS GONE.
Problem Solved.
Now you can proceed to turn on whatever you want on, such as:
Bluetooth On,
Location On, and
ALL APPS Notifications ON (Pushable).
