1. romjae's Avatar
    I just went to change my settings for the edge panels and noticed that the customization options are gone.
    The option to change transparency, which side or the location of the tab on the screen all seem to be missing. Is this a nougat thing? Or is there something wrong with my edge?
    04-26-2017 02:55 PM
  2. SpookDroid's Avatar
    Ummm, mine were still there until last week. Nougat update, T-Mobile version. Have you looked through all the settings? I also changed the settings on the S8 and they're still there, so don't see why they'd be gone on the S7E.
    04-26-2017 03:08 PM
  3. jamaica168's Avatar
    Bring up the panel, click the settings button, then in top left corner of edge panel screen click the 3dot menu and then handle settings. It's been moved in nougat.
    04-26-2017 07:23 PM
  4. romjae's Avatar
    Thanks Jamaica. I need to change the color settings on screen I guess because I had no idea there was even a button in that corner.
    04-26-2017 07:31 PM
  5. SpookDroid's Avatar
    Oh, yeah, a lot of themes do that, unfortunately haha especially after Nougat made everything light.
    04-26-2017 10:49 PM
  6. Virginia Smith42's Avatar
    on s8 Galaxy 11/29/19 software updates 11/19/19 At first Edge screen was automatically changing sides then I suddenly had NO edge screen and NO 3 dot menu anywhere on edge screen. OS PIE. After doing app updates (not system) when clearing cache, i found that biometrics app shuts down/fails. After going through Samsung Community, found a lot of similar issues after updates..but no solutions.
    Please, any help out there.
    11-30-2019 10:39 AM
  7. Virginia Smith42's Avatar
    11-30-2019 10:43 AM
  1. Is there a way to download apps to my new Nextbook?
    By LizzyGray in forum Android Apps
    Last Post: 06-27-2017, 10:09 PM
  2. Replies: 5
    Last Post: 04-28-2017, 05:10 PM
  3. There is microphone on keyboard of my s 8
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-26-2017, 04:39 PM
  4. Is this the mother of all flaws for s7e?
    By kupostic in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2017, 03:31 PM
