1. Lyra1963's Avatar
    Turned all app notifications off including wireless, NFC. Do not disturb doesn't even work.
    04-28-2017 08:54 AM
  2. SpookDroid's Avatar
    Hi there,
    Have you checked your Accessibility settings and see if you have the notification reminder set up (it re-spawns notification alerts when you have unread notifications on a set time interval). What about booting up your phone in Safe Mode? Does it do it there? If not, then it's an app causing the issue.
    04-28-2017 09:29 AM
  3. Lyra1963's Avatar
    Already checked all my settings, including accessibility. I'll try safe mode.
    04-28-2017 02:51 PM
  4. Lyra1963's Avatar
    Still beeping every minute in safe mode. And when typing in the text message box, the app minimized and refreshes while I'm typing. My battery is draining FAST.
    04-28-2017 03:31 PM
  5. pontiac005's Avatar
    Try and wipe cache..
    Turn off the device.
    Press and hold the following three buttons at the same time: Volume Up key, Home key, and Power key.
    When the phone vibrates, release the Power key but continue to press and hold the Volume Up key and the Home key.
    When the Android System Recovery screen appears, release the Volume Up and Home keys.
    Press the Volume Down key to highlight ‘wipe cache partition.’
    Press the Power key to select.
    When the wipe cache partition is complete, ‘Reboot system now’ is highlighted.
    Press the Power key to restart the device.
    04-28-2017 07:13 PM
  6. 1812dave's Avatar
    It might be service alerts. Do you have service alerts turned on?
    04-28-2017 07:57 PM
  7. Lyra1963's Avatar
    Already wiped cache before going to safe mode. I turned every notification off except for Messages, but I'll check service alerts again. Phone is acting weird in general. Have to keep keep it on silent and charge it in the afternoon; losing approx 10%+ per hour.
    04-29-2017 08:54 AM
  8. Lyra1963's Avatar
    All system notifications are off. Sill rings every 60 seconds, which is not the timing for any setting that has a time setting but is turned off.
    04-29-2017 11:12 AM
  9. Lyra1963's Avatar
    I think I found it! My cell was paired to my house phone. It may have unlinked and was trying to reconnect. I unpaired the 2 and haven't had a ring in 3 minutes!
    Dngrsone likes this.
    04-29-2017 12:32 PM
  10. SpookDroid's Avatar
    Ah, I forgot about this!!! Yeah, incoming BT connections will cause your phone to beep uncontrollably. It also happens if you name your device the same way as a previous connection (say, for instance, you always name your phone MCLOVIN and then you change phones but use the same name... your BT device might still try to connect but since they're not paired anymore, your phone will just start beeping and vibrating).
    04-30-2017 04:36 PM
  11. Lyra1963's Avatar
    Thanks so much for responding!!!!
    04-30-2017 04:51 PM
  1. Edge clock?
    By uncreativeartist in forum Samsung Galaxy S8 & S8+
    Last Post: 05-28-2017, 09:25 PM
  2. s7 edge unlocked US 7.0
    By mustang7757 in forum Samsung Galaxy S7 edge
    Last Post: 04-30-2017, 11:39 AM
  3. How to unlock my T-Mobile s7 edge
    Last Post: 04-28-2017, 02:58 AM
  4. galaxy s7 - alarm and reminder rings forever
    Last Post: 04-28-2017, 02:51 AM
  5. How can I recover my pictures on my Fried s6 edge?
    Last Post: 04-27-2017, 11:37 PM
