1. AC Question's Avatar
    In the past few days my phone has been on the fritz and so it's telling me there is moisture detected in the USB port or charger but that is impossible neither have been near any type of water or moisture I've tried a new cord multiple power sources then you blue tooth won't connect please if anyone has an idea let me know
    05-01-2017 03:50 PM
  2. Tim1954's Avatar
    Must have a faulty sensor there, I've seen that around a fair bit... Trying the old wipe cache partition trick, that cures most minor ailments...
    05-01-2017 10:40 PM
  3. fabris40's Avatar
    Did you reboot your phone?
    05-02-2017 03:41 PM
  1. can't find my keypad to make phone calls
    Last Post: 05-01-2017, 08:40 PM
  2. Replies: 3
    Last Post: 05-01-2017, 04:48 PM
  3. Replies: 1
    Last Post: 05-01-2017, 04:33 PM
  4. Why are some of my pictures covered in gray.?
    Last Post: 05-01-2017, 03:44 PM
  5. Removed SIM from G3 now having popup issue.
    By ch3micalrainb0wz in forum LG G3
    Last Post: 05-01-2017, 03:39 PM
