1. AC Question's Avatar
    Hi, so my question is "Does LCD need replacement if touchscreen and glass are only defective for Samsung S7 Edge?" I have a phone that has the glass broken and the touchscreen works everywhere except a line in the middle. Does the entire module, ie glass, digitizer and lcd need to be replaced or can I just replace the digitizer and glass?
    05-02-2017 03:26 PM
  2. Tim1954's Avatar
    Dial *#0*# to get service mode and you can test digitiser hardware there. And many other things...
    05-02-2017 08:00 PM
  3. IAmSixNine's Avatar
    While i have not taken apart a s7 edge almost all phones made with in the last few years have had the Glass and LCD or AMOLED glued together.
    So im pretty sure if you have a touch screen issue and/or broken glass the AMOLED screen will need to be replaced.
    Im sure you know this but the samsung galaxy s7 s7 edge use AMOLED displays, not LCD.
    05-03-2017 10:01 AM
  1. Replies: 3
    Last Post: 01-17-2018, 03:42 AM
  2. Replies: 2
    Last Post: 05-03-2017, 08:37 AM
  3. Replies: 0
    Last Post: 05-02-2017, 02:59 PM
  4. Replies: 0
  5. Replies: 0
    Last Post: 05-02-2017, 02:45 PM
