1. Air Planet's Avatar
    Why my s7 edge not sending long text message?
    05-06-2017 02:20 PM
  2. dov1978's Avatar
    I'm guessing its because you haven't got MMS set up properly. When the sms is larger than determined size it's automatically tuned into an MMS and if you haven't set that up properly or installed the settings from your network then they won't send
    05-06-2017 02:48 PM
  3. Air Planet's Avatar
    But why its need mms means sms to mms?and it it charged mms charges when it is convert sms into mms?
    05-06-2017 03:04 PM
  4. Air Planet's Avatar
    Anyone other knows?
    05-07-2017 04:36 PM
  1. AT&T Galaxy S8 Any issues buying Galaxy S8 Unlocked International SM-G950F ?
    By BenH4 in forum Samsung Galaxy S8 & S8+
    Last Post: 05-08-2017, 09:00 AM
  2. Why are cards not loading?
    Last Post: 05-06-2017, 08:45 PM
  3. Replies: 1
    Last Post: 05-06-2017, 08:25 PM
  4. Calendar reminders do not work
    By ags2 in forum Samsung Galaxy S8 & S8+
    Last Post: 05-06-2017, 03:35 PM
  5. Bought a new phone battery but doesn't work
    Last Post: 05-06-2017, 01:55 PM
