1. AC Question's Avatar
    Network mode option does not have and I can't choose 4G lte on my verizon S7 edge(1 sim).In my mobile network setting,just 4 options(Data roaming access,roaming,signal strength and access point name) have existed.How to fix it.
    05-07-2017 04:04 AM
  2. 1812dave's Avatar
    I don't know if it'll work but try resetting network connections
    05-07-2017 04:06 PM
  3. underway99's Avatar
    It sounds like you're not going far enough. Tap on NETWORK MODE.
    Your choices should be GLOBAL, LTE/CDMA, and LTE/GSM/UMTS. For use here in the US, keep it set to either GLOBAL or LTE/CDMA. Both should be able to access a 4G/LTE network.
    05-07-2017 08:45 PM
  1. Replies: 1
    Last Post: 05-08-2017, 10:34 PM
  2. Replies: 0
    Last Post: 05-07-2017, 03:54 AM
  3. Why my phone is over heating
    Last Post: 05-07-2017, 03:32 AM
  4. How do I change my email address on Yahoo?
    Last Post: 05-07-2017, 02:29 AM
