1. Robert Lindsay's Avatar
    I bought a refurbished S7 Edge last week. I did a factory reset so that i could ensure it was set up as a new phone, nothing was imported from my old backup.
    My old phone is a Moto g 3rd gen, i disabled as many apps and systems apps as i could to help with battery life and performance but eventually it still ended up performing slowly. I thought buying a Samsung s7 would give me a lot more performance and i would not need to worry about disabling apps and removing apps etc. I was wrong.
    I disabled a few of the obvious ones that i wont use like the microsoft apps and the google apps etc. I installed TomTom satnav app, Textra, Popweramp, Ccleaner, Phone Info.
    I noticed that when i type using Textra it was very slow, the other aps were a bit quicker so i removed Texta. My phone still felt slow, apps not opening quickly enough, i disabled facebook, this has improved things again but my phone still does not feel as snappy as it was when i first got it last week.
    So what is the secret to installing apps so that it does not slow my phone down? I thought this problem would be gone by now but it seems not. I was using Discomark to benchmark on my last phone but it does not work on Nougat. How can i test the performance of my apps opening and keep my phone snappy?
    Is there a tutorial on how to tweak your phone for better battery life and what apps i can disable that wont have a negative impact on my battery or my performance?
    05-07-2017 06:40 AM
  2. Tsepz_GP's Avatar
    What did you use to Disable those apps? As even the app Disablers cause more damage than they fix.
    Stay away from Package Disabler. I would say maybe​ Disable Google Chrome, and use the Samsung browser, and any other Google apps you don't need.
    Also, I suggest enabling Developer Options and making animations faster by setting them to 0.5
    05-07-2017 10:55 AM
  3. talberry's Avatar
    Maybe give it a couple of days for the phone to settle first and see if it gets better after that.
    05-08-2017 04:17 AM
  4. Robert Lindsay's Avatar
    Ok no problem, is there anyway of measuring or benchmarking with Nougat? Discomark no longer works.
    I uninstalled or disabled the apps by touching on the icon and selecting uninstall or disable, or i go into the applications in settings and do it from there. Is this an ok way of doing this?
    Is the Samsung browser better than chrome, i am used to chrome and i use it on my laptop, is it known to slow down Your phone?
    Thanks for the tip on the animation, i changed the animation scale on 3 settings is that correct, the windows do seem to be a bit snappier now.
    05-09-2017 09:57 AM
  5. Tsepz_GP's Avatar
    Yep, sounds like you got it all right.
    Yes, in my experience Samsung Browser is far better than Chrome. The Samsung Browser incredibly underrated as a browser, it's so efficient in terms of battery and does not use too much RAM either.
    05-09-2017 11:15 AM
  6. Robert Lindsay's Avatar
    Ok thanks for the info, i will give the Samsung browser a try and see what i think.
    05-10-2017 06:40 AM
  1. After used S8+ Can you go back to old design phone?
    By eak1570 in forum Samsung Galaxy S8 & S8+
    Last Post: 05-08-2017, 12:29 PM
  2. Network mode option does not have my verizon S7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-07-2017, 08:45 PM
  3. Network mode option does not have my verizon S7 edge
    Last Post: 05-07-2017, 04:04 AM
  4. How can I root samsung galaxy edge s7 with a connect wireless stick instead of Sims card
    By AC Question in forum Samsung Galaxy S7 edge Rooting, ROMs, & Hacks
    Last Post: 05-07-2017, 03:54 AM
  5. Replies: 0
