1. AC Question's Avatar
    My S7 Edge just had an update, its running 7.0. The broken cursor and dialog box mostly been appearing in Google apps like Google and Play Store, the imgur app showed the dialog box glitch. I'm not very sure about every app since I don't know how to trigger it in other apps.
    I have tried erasing the cache using the Android Recovery Mode. No luck. I'm just curious what's wrong. As far as I know its just graphical problem. Thank you.
    05-08-2017 12:13 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you give more details about the dialog box glitch? Is it when the blue teardrop-shaped cursor remains on the screen after switching apps? A screenshot may be helpful: http://forums.androidcentral.com/gen...d-central.html. You'll have to register on this forum first.
    05-08-2017 06:08 PM
  3. GenesisKun02's Avatar
    I'm sorry for not including them before, I tried to upload them to imgur, but it wouldn't let me post the thread. I'm new to this, sorry!!
    Why is my dialog boxes and cursors glitched?-18425669_120300003653023383_1825528653_n.png Why is my dialog boxes and cursors glitched?-18386866_120300003654186678_408662376_n.png
    I'm not really sure what to call it a dialog box/alert box or what. Sorry about that.
    As far as I know, it also occurs on YouTube and even the freshly installed Android Central app.
    05-09-2017 12:15 AM
  4. B. Diddy's Avatar
    Read through this thread -- does that sound familiar? http://forums.androidcentral.com/sam...ml#post5770380
    05-09-2017 02:38 AM
  5. GenesisKun02's Avatar
    Nope, not really.
    WHEN I WAS TYPING THIS, I UNINSTALLED KASPERSKY INTERNET SECURITY (Because it was not starting up at boot, and read that uninstalling it may help after a software update) AND WAS ABOUT TO REINSTALL IT, AT THE PLAY STORE I TRIED TO CHECK, AND THE CURSOR WAS NORMAL! UPON FURTHER CHECKING, THE BOXES ARE TOO! I'M SO SORRY FOR TYPING AT ALL CAPS, I'M TOO HAPPY THAT I FOUND THE CULPRIT.
    B. Diddy likes this.
    05-10-2017 12:13 PM
  6. B. Diddy's Avatar
    LOL, glad you figured it out!
    05-10-2017 01:42 PM
  7. mistaaah's Avatar
    Hi, this is the only post which mentions my issue, so I thought we can continue it. I have the same problem but don't have Kaspersky installed. How can I probably find out the icon files and check it it was tampered with?
    06-29-2017 11:49 AM
  1. Replies: 4
    Last Post: 05-12-2017, 07:50 AM
  2. DQA pop up to close - what is this?
    Last Post: 05-08-2017, 11:50 AM
  3. Different icons in My Activity Log
    By KimieBurch in forum Legacy Android & Other OS's
    Last Post: 05-08-2017, 11:40 AM
  4. Hacks and tricks for your new Gear VR
    By BeyondtheTech in forum Samsung Galaxy S8 & S8+
    Last Post: 05-08-2017, 11:08 AM
  5. Date and time of texts
    By Kassidy Smith in forum General Help and How To
    Last Post: 05-08-2017, 11:04 AM
