1. AC Question's Avatar
    My S7 edge crashes on start-up, with solid blue light and black screen. Initially, it kept trying to get past the Samsung logo and failed, now just black.
    I have tried recharging fully as I have seen that may have worked according to a tip, but this failed. I haven't tried doing a system restore in recovery mode yet as I have data on my phone that I haven't yet backed up that I can't access!
    Will there be a way of accessing my data before I know I have to do a hard reset?
    I'm not even sure if the phone will boot into recovery mode yet either.
    If all above fails, will I be entitled to a replacement from Samsung? I bought the phone in June last year.
    I also dropped the phone in October. This required a replacement screen. I then had a problem with the battery expanding in February and causing the phone to reset regularly with power dropping to zero. I got the battery replaced and this corrected itself. I don't know if these things are interlinked.
    I have seen other people have had my current problem, particularly with the early models, I believe this would have happened anyway despite my dropping the phone. Will Samsung see it this way?
    05-12-2017 05:30 AM
  2. matthewkuhl's Avatar
    Only Samsung can answer the warranty question
    05-12-2017 06:42 AM
  1. How much longer will Whatsapp support android 4.x
    By milleniumdroid in forum Ask a Question
    Last Post: 05-19-2017, 02:29 AM
  2. Replies: 1
    Last Post: 05-12-2017, 03:45 PM
  3. Replies: 0
    Last Post: 05-12-2017, 05:16 AM
  4. Replies: 1
    Last Post: 05-12-2017, 05:05 AM
  5. Moto G would not shut down and now I can't get it to start.
    Last Post: 05-12-2017, 04:40 AM
