1. cardboard60's Avatar
    I have a S7E phone that was on At&t.
    Got a unlock code.
    Put a verizon sins card and put it in the phone, it asked for the unlock code.
    I put it in and it said successful.
    It will not connect to Verizon network.
    Is that because I need to change the VPN numbers over to verizon too .
    05-12-2017 09:01 PM
  2. Iva_LadyDiCaprio98's Avatar
    At&t can only be unlocked to other GSM carriers like T-Mobile, straight talk, etc. It will not work with CDMa like Verizon or Spring. For that you would actually have to get a phone with CDMA bands which neither At&t or T-Mobile have
    05-13-2017 01:58 PM
  3. IAmSixNine's Avatar
    APN not VPN.
    And as Iva_LadyDiCaprio98 mentioned its GSM vs CDMA.
    You MIGHT be able to get some stuff to work with Verizons LTE network if you update the APN settings. But i wouldnt rely on that. Sell the phone or use T-Mobile.
    05-16-2017 03:18 PM
  4. troshs's Avatar
    Only thing you can use it for is straight talk if you get an att card from them. I did it and my s8 edge is fine.
    05-16-2017 07:23 PM
  5. mrluky60's Avatar
    You have a paper weight.
    05-16-2017 07:23 PM
  6. IAmSixNine's Avatar
    OR Tmobile.
    Or any of their MVNO. Cricket, Straight Talk. MetroPCS.
    troshs likes this.
    05-17-2017 08:25 AM
  1. Replies: 1
    Last Post: 05-13-2017, 03:22 AM
  2. Replies: 1
    Last Post: 05-12-2017, 09:13 PM
  3. How do i find wizard setting in my phone to turn it off
    Last Post: 05-12-2017, 08:46 PM
  4. What do the two circles by camera on front of galaxy sky do
    Last Post: 05-12-2017, 08:38 PM
  5. Airdrop on Android?
    By alpha752 in forum Ask a Question
    Last Post: 05-12-2017, 08:16 PM
