1. talberry's Avatar
    Hey all,
    I'm currently using a spigen Crystal case for my s7 edge, but the thing is that it keeps pushing the edges of my screen protector out, so there's lots of air bubbles and it looks awful.
    Anyone has a minimalist case to recommend which allows me to use it with the screen protector?
    05-14-2017 04:42 AM
  2. manos_lourakis's Avatar
    Hello talberry! I use this spigen case: https://www.spigen.com/products/gala...nt=11973051457 and there isn't any problem with my screen protector.
    05-14-2017 10:13 AM
  3. talberry's Avatar
    I see! Thank you!
    I'll go take a look at that! Have you been using that case for long?
    05-14-2017 07:26 PM
  4. underway99's Avatar
    I have the Neo-hybrid Crystal from Spigen. Also no issues with the Zagg HD film screen protector.
    05-14-2017 07:30 PM
  5. steffnz3's Avatar
    Curious, what screen protector are you using? I'm using Armour Shield and have gone thru two. They keep greeting pushed up at the bottom using a Spigen case.
    05-14-2017 11:11 PM
  6. manos_lourakis's Avatar
    I see! Thank you!
    I use this case from the first day I bought my phone. And believe me, I will buy exactly the same case again ๐Ÿ˜‰
    05-15-2017 12:37 AM
  7. talberry's Avatar
    I've just ordered mine looking forward to using it! Thanks!
    05-15-2017 07:00 PM
  8. talberry's Avatar
    Just got mine and I'm using it right now. Fits perfectly and doesn't spoil the screen protector! Thanks for the recommendation!
    05-21-2017 07:05 PM
  9. manos_lourakis's Avatar
    05-27-2017 03:08 AM
  1. Replies: 3
    Last Post: 05-19-2017, 08:41 PM
  2. Replies: 2
    Last Post: 05-14-2017, 11:32 AM
  3. Replies: 1
    Last Post: 05-14-2017, 04:53 AM
  4. Replies: 1
    Last Post: 05-14-2017, 04:51 AM
