1. Ghea Hall's Avatar
    I purchased the Screen Beam Mini 2 dongle to screen mirror my phone. My problem is that the Quick Connect feature is not present on my phone where the instructions, youtube videos and online searches have stated that the feature is to be found. I AM IN NEED OF ASSISTANCE MON and any advice or instruction shall be greatly appreciated mon. Thank you so much in advance to all.
    Steph6n likes this.
    05-14-2017 01:47 PM
  2. msndrstood's Avatar
    What phone do you have?
    05-14-2017 02:27 PM
  3. Ghea Hall's Avatar
    S7 Edge
    05-14-2017 02:44 PM
  4. jhimmel's Avatar
    I believe I saw another user with this problem. Try searching the forums, I think he wound up getting it back somehow. Are you using any 3rd party launcher?
    05-14-2017 06:15 PM
  5. Ghea Hall's Avatar
    Thank you for the tip and I am unaware of (or at least there should not be) any 3rd party launcher attached to the phone.
    05-15-2017 07:46 AM
  6. Roynato's Avatar
    Android Nougat?
    Go to Settings, Connections, More Connections Settings, Nearby device scanning
    05-15-2017 12:45 PM
  1. Samsung note 5 quick settings at top of note 5 disappeared
    Last Post: 11-25-2017, 12:06 PM
  2. Reboot loop on Tab 2 10.1 - Can I backup the data?
    Last Post: 05-16-2017, 01:38 PM
  3. How to by pass the screen lock
    Last Post: 05-15-2017, 02:07 PM
  4. How do I change the emojis I see?
    By Chloe R in forum Ask a Question
    Last Post: 05-14-2017, 07:14 PM
  5. Is quick connect not available on s7 edge?
    Last Post: 05-14-2017, 01:14 PM
