1. cybersud's Avatar
    I would like to silence my phone for specific hours (at night) each day automatically but still allow my "favorites" to contact me if needed.
    I tried using the Do Not Disturb which does stop calls and texts, but doesn't quiet the whole phone (still get notification on calendars, etc)
    I tried using silence, but you can't use that with your favorites list.
    Any suggestions?
    05-15-2017 04:00 PM
  2. Steven Frost1's Avatar
    The do not disturb function can be customised so only favorites can wake you during set hours.
    All other functions are silent you can set it between set hours.
    It really does work
    Dngrsone likes this.
    05-16-2017 01:24 AM
  3. Steven Frost1's Avatar
    A screen shot of settings
    Attached Thumbnails Do Not Disturb / Silence question-4489.jpg
    05-16-2017 01:27 AM
  4. BrutalhonestyM's Avatar
    Well you could disable push notifications, that way you wouldn't receive a notification from a certain app.
    Swipe the notification dashboard from the from the top, then below that you see 'notification settings'.
    Or if you cannot find that you can go to settings > notifications > then you have the option to disable all notifications. On the upper right corner you can click on advanced to show the apps silently etc.
    Hope this helps
    05-16-2017 11:00 AM
  1. How do i get date time and temperature back on my homescreen?
    Last Post: 06-14-2017, 03:10 AM
  2. Talking to text does not keep the screen on beyond the screen timeout feature
    By THEPRFCT10 in forum Samsung Galaxy S8 & S8+ Cases & Accessories
    Last Post: 05-25-2017, 10:19 PM
  3. Screen overlay for Joyce black how do I how do I uninstall it
    Last Post: 05-15-2017, 05:52 PM
  4. Why won't facebook and browsers not connect while in 4g
    By GazzZzzP in forum Samsung Galaxy S8 & S8+
    Last Post: 05-15-2017, 03:54 PM
  5. Replies: 0
    Last Post: 05-15-2017, 03:21 PM
